Time Domain Reflectometer (TDR)
Table 1. Time Domain Reflectometer product support
Feature
Product
Release introduced
Time Domain Reflectometer (Cable Diagnostic)
5320 Series
Fabric Engine 9.0.2
5420 Series
Fabric Engine 8.10
Not supported on 5420F-24S-4XE
5520 Series
Fabric Engine 9.0.2
Not supported on 5520-24X or 5520-48SE
5720 Series
Fabric Engine 9.0.2
7520 Series
Fabric Engine 9.0.2
Supported on 7520-48XT-6C
7720 Series
Not Supported
VSP 4900 Series
Not Supported
VSP 7400 Series
Not Supported
With Time Domain Reflectometer (TDR) cable diagnostic, you can test Ethernet cables connected to a switch port, or ports, for defects. Use this functionality to diagnose a link with poor connectivity. The cable diagnostic detects the state of the port or ports, the status of the cable pairs, and the length of the cable.
You can perform TDR cable diagnostic on copper ports.
The following table lists the states of the cables connected to a port or ports.
State Description
Ok
No cable fault is detected.
Open
Detects lack of continuity between the pins at each end of the cable.
Short
Detects a short circuit in the cable.
Open/Short
Detects either a short circuit on the cable or a lack of continuity between the pins at each end of the cable.
Crosstalk
Detects interference and degradation between two pairs in the cable.
Unknown
Detects an unknown issue.
